Fuel gauge not working
Stopped working the other day don't know why just wondering what is most likely the problem i have a 305 with the digital dash and it stays on full is it the fuel sending unit a sensor etc.. any info would be greatly appreciated.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Fuel gauge not working
If I'm not mistaken ( I am wrong sometimes ! ) If the electrical connections to the gauge are removed - like a broken wire - then the fuel gauge will shoot past the FULL reading. Where is the needle resting ???
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Its probably a jacked sending unit. This is almost expected of third gens at some point in time.
My friend had one that had a simular problem and his had a bad connection back by the tank where the wires go from the tank to frame and then up to front, the connector at the tank was bad corroded and the ground wire was pulled and cleaned connector and area it bolts to. The another friend had the wires going into the sending unit in the tank melted together. He took and put a fuel door over where the sending unit is in tank so if it happened again he didnt have to pull the tank, just lift the carpet and open door to get to it.
well the power supply has a wire saudered in directly from the fuse panel to power the fuel pump which was done because the fuel pump wasnt getting power so they kinda rigged it when i bought it but it was working before that theres 3 wires a power wire ground and signal
Ghettobird52
Jul 5, 2024 11:18 PM
R3500
Aug 17, 2015 12:16 PM
