Cruise Control Problems
Old Nov 4, 2007 | 11:36 AM
Red_Dragon_91's Avatar
Car: 1992 Chevy Camaro Heritage Edition
Engine: 305 TBI
Axle/Gears: Stock
i have a 92 rs 305, and my cruise control does not work and i would really liek it, i have no clue were to start to thry and figure out the problems cause i have never really messed with them before, any inout would be good,and yes i have checked all of my fuses
Old Nov 4, 2007 | 01:02 PM
Dmans85's Avatar
Car: '85 Z28
Axle/Gears: 3.23 posi
Re: Cruise Control Problems
Transducer was problem on mine. Not sure if this is the common culprit however. The vacuum assenbly is located on drivers side close to headlights. mechanical operation, hose integrity, and vacuum check would be a good start
Old Nov 4, 2007 | 01:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The brake pedal switch is a common failure as well.
Old Nov 4, 2007 | 02:00 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Also one on the clutch pedal for the T-5.
A failure there may also affect the HVAC system, it will cause the system to default to defrost only.
Old Nov 4, 2007 | 02:12 PM
Engine: 305 TBI
Axle/Gears: Stock
ok iam kinda lost like i said i have never messed wiht this crap before, and i do have a t-5, so how would i go about chekcing all of this stuff? and any clue how much it would cost to replace it, junkyards aint got any maros or birds
Old Nov 4, 2007 | 02:42 PM
Al Hasse's Avatar
For the pedal switches, you can get up under the dash and see the switches at the top of the pedals. The switches are basically buttons that are released by the linkages of the pedals. Here's mine, looking up from the floorboard, the clutch has one switch on it, the brake has two - one each for the brake light and cruise release (I forget which is which)
Old Nov 4, 2007 | 03:12 PM
Engine: 305 TBI
Axle/Gears: Stock
thats kick *** man thanks for the pics ill go check that out, if that doesnt work what else shoudl i try, also is there another way to check the cruise other than driving there car caus ei just got it shipped here from germany and its not registerd and no insurence yet lol
Old Nov 4, 2007 | 10:05 PM
Al Hasse's Avatar
Use this link from the sticky at the top of this forum, scroll to the last figure (Figure 62: 1992 body wiring) and the cruise is on the bottom right of the schematic. This should give you a starting point for the electrical part...
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Nov 5, 2007 | 12:33 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
How would you know the cruise works if you haven't driven it yet lol. You must go above 25 or 30mph (I can't remember) for it to be able to engage first of all.
Old Nov 5, 2007 | 08:31 AM
Engine: 305 TBI
Axle/Gears: Stock
lol i shipped it to louisiana from germany, i was dirving it over there since march, and i could not get it to work over there no matter what speed i was going, also where in the dash is the light for the cruie controll?
Old Nov 5, 2007 | 08:36 AM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
I didn't think they had the light on the third gen cars
Old Nov 5, 2007 | 04:12 PM
Engine: 305 TBI
Axle/Gears: Stock
lol well that sucks, anyway to put a light in?
Old Nov 6, 2007 | 12:14 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Red_Dragon_91
Take a look at the photo Al posted. On the braek pedal there are two switches. The left switch is an electrical switch that powers the brake lights (may be seperate circuits for the tail brake lights and the third brake light) and the cruise control disengage switch. On the right is a vacuum swich which also disengages the cruise control. If you look very closely, you can just see the vacuum hose on the top.
If you have a manual tranny you should also have a combination electrical/vacuum switch on the clutch pedal. The electrical contact on the clutch pedal will be wired in series with the switch on the brake pedal to disengage the crusie control if either pedal is depressed. The vacuum switch will be connected in parallel with the vacuum switch on the brake pedal. This is accompolished with the vacuum hose ending on the clutch pedal, going to a TEE connection at the brake pedal. On side of the TEE will go to the vacuum switch on the brake pedal and the other side will disappear into the wiring harness, out to the engine compartment and the vacuum servo.
I have the 82 shop manual which has an on car service check routine. However the transducre was changed in 84 or 85 so the one refered to in this routine will not match yours. I also think some of the wire colors and connections changed when GM changed the transducer design. I can post it but you will have to do a little research on the link Al provided to verify wire colors, etc. Also, I expect the transducer test listed in my service manual will not apply to the transducer on your car due to the different design.
Dave
Old Nov 6, 2007 | 08:03 AM
Engine: 305 TBI
Axle/Gears: Stock
ok thanks for the info guys, now i just gotta find time to take a look at it and put m y german plates on and go for a spin, ill let yall knwo how it goes
Old Sep 28, 2009 | 07:49 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
my car is in park. my dad accidentally put the cruise control on. so i press the cruise control reset button and my cruise control surges to 7000rpm red zone . i shut it off immediately. it never did that before. my idle also went up to 1500- 2000Rpm
Old Oct 9, 2009 | 04:59 PM
KITT1983
Sorry for not responding sooner, but I have been off the board for a couple of months. The most likely cause of your problem is a failed transducer, which is feeding a full vacuum to the vacuum servo and pulling the throttle linkage to full open.
Are you familiar with the cruise control components, or do you need a few pictures?
If you know where the vacuum servo is, with the engine off, disconnect the vacuum line to it and plug the line. Now start the car and see if the high rpm problem goes away. If so the transducer is bad.
The other clue that the transducer is bad is that the cruise control has a safety feature that disables the cruise when the speed of the car is under 35-40mph. The fact that it appears to be engaging in park highlights this as the likely problem.
Old Oct 9, 2009 | 06:57 PM
KITT1983's Avatar
Originally Posted by 82CrossFire Z28
KITT1983
No, I am not familar with anything of the cruise control system but I am learning as I go along
do you have any pictures of all the cruise control components and a guide to what their functions are?
When I start my car it idles at 2,000 RPM then goes to 1,000 RPM
after engaging drive the RPM goes down to 600 RPM idle
Old Oct 20, 2009 | 06:54 AM
KITT1983's Avatar
after looking further into the problem. my cruise control throttle cable has a kink in it. the problem of the RPM surging and high idle on cold start up was still there.
but when I disconnected the power cable to the cruise control. the high idle disappeared.
I think it is the cruise control transducer and I have to replace cruise control throttle cable.
Old Dec 14, 2009 | 07:29 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
If you have a cruise that does not work at all, what would you change first, would it be the control module?
Old Jun 9, 2015 | 03:52 PM
Raymon's Avatar
Car: 1989 IROC-Z convertible
Engine: 5.0
Transmission: Borg Warner T5
Axle/Gears: Yet to be determined
I did a T-5 conversion on my 89 IROC conv. Brake cruise control switch was fine. When I connected it, in parallel, to the clutch switch, neither would work. I got a vacuum 'T' & ran vacuum to both switches, but disconnected the wiring from the clutch switch. Now break switch will disengage the cruise control, but the clutch only prevents the engine from revving. Will it work correctly if I reconnect the wires from the brake switch (in parallel)?
Old Jun 17, 2015 | 03:00 PM
myzticc66's Avatar
Car: 1987 Chevy Iroc Z
Transmission: 700 R4
I have a 1987 Iroc Z 305 TPI I am having cruise control issues also. The vacuum lines are good and I replaced the turn signal column. It looks to me like the brake pedal switch is bad. I can see the spring that I'm sure should be inside the plastic tube. I have a attached photo. It has part# 25523376 7079 stamped on it. I'm having a hard time finding the part. Is there any other part that should fit this? Anyways any help would be awesome. Hope I'm posting this in the right spot. Thanks!
Old Jun 21, 2015 | 10:21 PM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
I would like to know that. It seems that changing the module would be a pain.
Old Jun 21, 2015 | 11:57 PM
myzticc66's Avatar
I found it at Oreillys. This fits a 87 Iroc automatic. Went in real easy. Just have to make sure both switches are adjusted correctly. both should be touching the metal plate by the brake lever and both should separate from the plate when the brake is pressed.
http://www.oreillyauto.com/site/c/de...yword=25523376
Old Jun 22, 2015 | 06:08 PM
podiatra's Avatar
Engine: 350 swap
Great! i will need to get similar part.
Old Jun 27, 2015 | 01:51 PM
podiatra's Avatar
Engine: 350 swap
Hi guys!
Where is the cruse control module? Is it behind the dash board?
Thanks!
Old Jul 19, 2015 | 04:49 PM
KITT1983's Avatar
any updates ?
Old Jul 19, 2015 | 06:36 PM
podiatra's Avatar
Engine: 350 swap
I dismounted my servo and seems that it works. Clean it up. Recheck all my hoses for kinks and didn't dind any. Tighten throttle cable. Check my wiring around the steering column and are intact. Clutch and brake switch seem to be working.
The previous owner of my car hacked it electronically. I am suspecting the the cruise control module needs to replaced. At this point the cruise control does nothing whatsoever.
Old Aug 19, 2015 | 09:26 PM
podiatra's Avatar
Engine: 350 swap
Does anybody knows how to best access the cruise control module ? I was able to find the ECM underneath the dash in passenger side. My service manual shows it somewhere to the left of the ECM but I can access that area of the dash...
Old Aug 20, 2015 | 05:55 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Just a random thought, but the cruise control won't work if your third brake light is burned out..... took me a lot of head scratching to figure that one out!
Old Aug 20, 2015 | 06:00 AM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Great info to know. this is probably my problem. Was working before my brake light went out but I didn't associate the two, thanks.
Old Aug 20, 2015 | 11:24 AM
podiatra's Avatar
Engine: 350 swap
Great, I will need to check, thanks!
Old Aug 20, 2015 | 09:57 PM
podiatra's Avatar
Engine: 350 swap
3rd brake light is working....
Old Dec 14, 2015 | 06:13 AM
KITT1983's Avatar
any updates ?
Old Dec 14, 2015 | 07:20 AM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
I guess I got real lucky. I replaced the turn signal stalk with a new one and my cruise started working again in the GTA. So I dissected the old one to see why ... the stalk has a metal rod inside of it, it was rusty .... new one works great. $15 on ebay.
Old Dec 15, 2015 | 12:13 PM
podiatra's Avatar
Engine: 350 swap
My clutch switch needed adjustment.
Old Aug 6, 2017 | 07:46 PM
Shakenblake's Avatar
Car: 1988 camaro iroc z
Please elaborate. I have no cruise control at all but I also have no speedometer/odometer and defrost only air. thanks. 1988 305 tpi 700r4, but I'm going to guess that my cruise issue would probably be corrected I'd my Speedo worked. And that the air/vent issue is another problem.
Old May 30, 2019 | 12:10 PM
rushtk's Avatar
Car: Teal 92 Z28
Engine: 5.7
Having same issue with my sons 92 Z 350, trying to find any post for an idea.
Old Oct 28, 2020 | 04:30 PM
1badcj8's Avatar
Car: 89 Iroc Z G92
Engine: 5.7 HO
Axle/Gears: 3.43
Does anyone have a picture of the "Transducer" When I Google it I get a butt ton of different things, none of which say anything about the cruise control system. Thanks...
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
