whats this relay do?
Old Nov 15, 2007 | 09:24 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
i was digging around in my hatch area on my 82 camaro and found a relay mounted under the far rear panel. Cant find anything in the books about it. what's it for? its by the left taillight on the inside.
Old Nov 17, 2007 | 11:55 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: whats this relay do?
I have an 82 Camaro also and am not aware of any relay in the area you describe. What color wires are connected to it? Perhaps you could post a sketch of the wiring ( showing what color wires are connected to the relay coil and what color wires are connected to the relay contacts) or pictures of the relay and its location.
Dave
Old Nov 20, 2007 | 07:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have a feeling that what you are seeing is the hatch release solenoid which is located in the area that you are describing.
Old Nov 20, 2007 | 08:55 PM
82Five-O's Avatar
Car: 82 Sport coupe
my camaro does not have a hatch pop button, i need to look closer at the object to determine what it really is, i just noticed it. i will post my findings tomorrow
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
