car only turnsover sometimes??
Car: 92 Z-28 "Z03"
Engine: 5.7L TPI
i have a 92 z-28...my problem is that the car will only start sometimes. I have looked through the threads but have found no concrete answer. The car sounds like it is going to turn over but it just doesnt. Usually the first turn of the key it will turn over and run or it will start and shut off. After that it will not turn over w/out a jump. Its like the voltage is a tiny bit low or something. I have heard it could just be the ignition switch? what do u guys think.
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: car only turnsover sometimes??
Sounds like a charging system issue if you need to jump it immediately after to get it to run. Does it run after you jump it normally or just shut off again? Everything else work otherwise (dash lights, buzzer, accesories)? Have you checked to make sure the battery is connected properly? It may be the ignition switch but thats not all that frequent of an issue, and not fun to replace. Give us some more details, and things you've tried.
Car: 92 Z-28 "Z03"
Engine: 5.7L TPI
You need to get a lil background info on the alarm system to see how advanced it is...if it will kill power to the fuel pump or kill the car as some security feature. Is this motor 5.0 or 5.7 and TBI or TPI?
could be poor ground, can you figure out if your getting spark the first time when it doesn't want to start? I don't know much about VATs, neone on here think it may be the system? I know on my newer truck with the programmed key my signal in my key was weak and would work sometimes and not others...
Car: 92 Z-28 "Z03"
Engine: 5.7L TPI
i am having the security system(was a viper system to auto page) upgraded this weekend. Hopefully it will start for the guys installing it and this may fix the issue.
From doing some reading it really sounds like the ignition switch, but i just cant be sure cause i dont know alot about that.
Linson
Aug 21, 2015 02:12 PM
