tach doesnt work....cant go past certain rpm
Old Nov 20, 2007 | 04:51 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
well im still fiddling with the car and i replaced the ground bolt to the firewall, checked the bolt to the head and they are good. However, the tach doesnt work at all, and just to see something, I tried to ride out first gear to about 45mph. Well at about 30-35 mph, the car acted like it was bouncing off a rev limiter. Last time this happened to me, I tightened up the ground bolt to the firewall and everything was fine. need help asap.....vehicle inspection runs out this month and dont have $/time/patience to mess with this thing all winter.
Old Nov 20, 2007 | 06:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: tach doesnt work....cant go past certain rpm
have you checked the white wire going from the tachometer to the ignition coil?
Old Nov 21, 2007 | 09:47 AM
Car: 92 Camaro
Axle/Gears: S60 373
ill check it today
Old Nov 24, 2007 | 01:07 PM
Car: 92 Camaro
Axle/Gears: S60 373
ok got tach working but got tha rev limiter crap on there still
Old Nov 25, 2007 | 10:27 AM
Car: 92 Camaro
Axle/Gears: S60 373
nobody has any ideas?
Old Nov 25, 2007 | 02:53 PM
Car: 92 Camaro
Axle/Gears: S60 373
update- now it wont start
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
