Brake Light Switch/Torq Conv Unlock
Old Nov 29, 2007 | 08:18 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
Is the brake light switch what tells the tc to unlock?
If so, does anyone know which wire is for the tc?
If you do, is the curcuit open or closed with an open switch?
I know it's a lot to ask at once, but I need help a.s.a.p. Thanks guys.
Old Nov 30, 2007 | 01:13 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Brake Light Switch/Torq Conv Unlock
The TCC solenoid gets +12v through a switch on the brake pedal. Pressing the pedal opens the circuit.
Old Nov 30, 2007 | 06:44 AM
Car: 89 camaro rs
Engine: 305 tbi
thanks Apeiron. thats exactly what i needed.
Old Nov 30, 2007 | 06:34 PM
Car: 89 camaro rs
Engine: 305 tbi
ive had no luck in the transmission board for the problem im having.
when its time for the tc to lockup my cars shutters bad; applying the brakes slightly smooths everything out. so for now, i want to make my tc 'think' im braking to keep it from locking up.
im going to unhook the tc wires as a temporary fix for my problem.
thoughts?
Old Dec 2, 2007 | 04:16 PM
Car: 89 camaro rs
Engine: 305 tbi
seriously, ive never gotten no response on the board before, wtf?
Old Dec 2, 2007 | 05:52 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
If you unplug the contact on the brake switch that has the pink/black and purple wires it should do the trick. There will be no adverse effects from doing this under normal driving conditions, only a slightly lower mpg.
There has to be a first time for everything you know..
Old Dec 2, 2007 | 08:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Along with reduced mileage, you'll also have increased transmission temperatures while cruising in O/D.
Old Dec 2, 2007 | 08:42 PM
Car: 89 camaro rs
Engine: 305 tbi
yeah yeah... lol thanks for the reply btw.
and Apeiron, the tc slipping in OD is what would cause the higher temps?
Old Dec 2, 2007 | 08:48 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
yes.
Good thing you dont have the earlier transmission.. Those would actually burn out without the TC locked.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
