Manual T5 Neutral Switch?
Old Dec 5, 2007 | 01:53 PM
serpentineocean's Avatar
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
Hey All,
I've got a '91 RS Convertible, 5 Speed Manual. 305 TBI. I'm told to assume the stock transmission is a T5. This being said, doing some google-ing and i know at least the Ford T5 has a neutral safety switch (I'm guess the only difference between a ford, jeep, GM T5 is the gear ratios and bell housing and such).
Does anyone know if my car above would have a neutral safety switch already? The Haynes manual doesn't seem to show one. And if it doesn't, anyone know any reason why i couldn't install one.
FYI - I'm looking to use the neutral safety switch when i go to install a remote start. Obviously, i'm not a fan of 'just remember to leave it out of gear' theory.
Thanks for any help guys.
Old Dec 5, 2007 | 02:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Manual T5 Neutral Switch?
You've got a clutch switch, not a neutral switch.
Old Dec 5, 2007 | 02:12 PM
Car: 1986 Vert Z28
Yea, the plan is to tap off of those wires (purple/yellow i think), so that the car will start with the clutch depressed and/or the gear is in Neutral.
Old Dec 5, 2007 | 02:33 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Sorry, I have never seen a domestic with a neutral switch.
I also needed one and had to make it myself.
Some remote start systems are smart, though. They have you park the car, leave it in neutral and running and exit the vehicle. When you push the button to lock the doors, it shuts down the engine. Then when you press the remote start button next time, it assumes that nobody has broken into the vehicle and put it in gear and can start the car.
Lou
Elephantismo
Feb 13, 2019 12:51 AM
Veaceonee
Sep 29, 2016 08:15 PM
RyanJB
May 7, 2016 06:23 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
