Fixing voltage problems
Old Dec 20, 2007 | 11:05 AM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
I posted a while back about how I'm having issues with my '89 IROC's voltage dropping as the car runs for a while. I did some searching, and I think know what I should do. Someone please doublecheck my plan and tell me if I'm missing anything.
I want to clean the grounding strap at the back of the engine. I'll also make sure where it bolts to the engine and chassis is clean of rust/paint.
Check the battery ground, which I think is at the starter solenoid? Again, clean off rust/paint.
Since I believe the problem started not long after I installed my SPAL fans, I'll doublecheck the wires to the fans, and the chassis ground behind the fan relays next to the battery as well.
Is there anything else i should do?
Old Dec 23, 2007 | 08:33 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Re: Fixing voltage problems
No love, huh guys?
Old Dec 24, 2007 | 01:47 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
i have the same problem. my voltage drops as i run the car for a while.
however i have that annoying chime when i turn the car on. the chime that goes on when you leave your lights on or when you have your door open and the key in the ignition.
haven't been able to trace it. i was gonna add other ground strap from the block to the car
GTAman
Mar 15, 2019 11:40 AM
theshackle
Mar 5, 2017 06:37 PM
dyeager535
Aug 28, 2015 08:10 AM
Bert87
Aug 23, 2015 03:50 PM
