How do you wire this up?
Old Dec 20, 2007 | 05:49 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Was tired of amp draining battery. Purchased a 160 amp Delco palladium alternator. It pluged right in, BUT. There is a wire coming from positive side of battery that hooked to a bolt on the back of alternator. This has a big brass eyelet on the back. Do I just use a bolt and hook to the back. Dont want to blow anything, please let me know. Thank you!
Old Dec 21, 2007 | 02:44 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: How do you wire this up?
Don't bolt it just anywhere on the back, that is mostly ground there, and the wire would blow up or start a fire (unless it has a fusible link which would blow) as soon as you hook up the battery. The positive, red wire with the brass eyelet has to be bolted to the insulated B+ terminal on the back of the alt.
Remember to always disconnect the negative battery terminal first, and connect it last, when doing electrical work like this.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
