Where is this fuse located?
Old Dec 31, 2007 | 02:55 PM
berryghardwick's Avatar
Car: 89 IROC-Z
Engine: 89-TPI 5.7
I have an 89 IROC and need to know where the 20 amp inline fuse for the fuel pump relay, fuel pump/oil pressure switch, mass air flow relay, and the burn off relay is located. The wiring diagram I have says that it is suppose to be hot at all times, and I do not have any power to any of these relays.
Old Dec 31, 2007 | 07:31 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Where is this fuse located?
Not sure if it's the one you seek, but there is a 20amp fuse in the passenger well, under hood, kinda gets tucked behind battery - try that.
Old Dec 31, 2007 | 09:11 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I'm not sure if there was a change but off the battery was a fusible link to the oil pressure switch for my '83 CFI Z28.It was crushed while working and once she was back together got no fuel from the injectors.Tracing the wiring gave me this and repaired it and fixed the problem.
Old Jan 1, 2008 | 10:51 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
On an 89, I'd say in the default battery location. It's usually attached to the fenderwell and looks like an unused connector so it can look very deceiving.
Lou
Old Jan 2, 2008 | 06:16 PM
Car: 89 IROC-Z
Engine: 89-TPI 5.7
I found it!!! It was right where y'all said. We are rolling again! Thank you
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
tonys91rs
Sep 2, 2015 07:07 PM
