brake light problem
Old Jan 15, 2008 | 09:25 PM
gr8_syder's Avatar
brake light problem
ok so i have a problem with my brake light. it works when the tails are off but the passenger one is really dim, then u turn on the lights and hit the passenger light goes out and only the driver one stays lite. if anyone could help me out it would be really great
btw its a 1995 with the 3.4l
Old Jan 15, 2008 | 09:49 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: brake light problem
That sure sounds like a bad ground on the tail lights.
It could be just a bad gound contact on the lightbulb or maybe a bad connection in the black ground wire splices behind the tail lights.
If you test each black wire on each socket, it should always read 0V, no matter what lights are on.
Lou
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
