blower motor fuse keeps poping
Old Jan 19, 2008 | 09:39 PM
84HyperZ's Avatar
Car: 1984 Z28
Engine: 4bbl 305ci
Axle/Gears: 10 bolt 3.42 w/ Auburn LSD
this has been going on for a while now and it is really starting to annoy me. It will occasionally be fine and not pop for a while no matter how many times i turn the speed up or down/ on or off. But then other times (just like tonight when it is 30 f*%&^%g degrees outside)when i just refuses to be turned on at all. I am pretty sure my alternator is going out but it has been doing this even before the alternator issue. So aside from the alternator, what other possibilities could there be?
Old Jan 20, 2008 | 12:36 AM
w01fm4n's Avatar
Car: 1991 Chevy Camaro RS
Engine: 305/5.0 Liter V8
Transmission: Borg-Warner T-5
Axle/Gears: Stock... Not Sure Yet
Re: blower motor fuse keeps poping
improper ground?
Old Jan 20, 2008 | 12:44 AM
84HyperZ's Avatar
Car: 1984 Z28
Engine: 4bbl 305ci
where tho? i have checked everywhere i can think of.
Old Jan 20, 2008 | 04:42 AM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
Sounds like the blower motor is drawing too many amps and blowing the fuse. I would replace the blower motor.
Old Jan 20, 2008 | 07:02 AM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I'm number 2 for replacing the blower motor
Old Jan 20, 2008 | 08:52 AM
84HyperZ's Avatar
Car: 1984 Z28
Engine: 4bbl 305ci
oh yea i have tried that one too but it still did it then also. the only other thing i can think of could be wrong would be something with the vent control panel. so aggrevating
Old Jan 20, 2008 | 01:00 PM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
I think the only two remaining components are the resistor and the switch. Does the fan have all of it's speeds working correctly? Does the switch feel weird when switching to different speeds?
I would check the plug-ins at the resistor and switch. See if they are burnt or discolored.
Old Jan 20, 2008 | 06:05 PM
84HyperZ's Avatar
Car: 1984 Z28
Engine: 4bbl 305ci
yea it has all of its speeds (well other than the obvious, when the fuse blows). what do you mean by feel weird? like hard to turn?
Old Jan 21, 2008 | 03:43 PM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
yes, hard to turn or turn better in one spot compared to another. This would lead me to the switch and not the resistor.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
