New member, got some wiring ?'s
Old Jan 31, 2008 | 09:48 PM
Explosivpotato's Avatar
Hello everybody, I just picked up an 87 Firebird with a 355 motor and a holley 650 (according to the seller it used to be a 305 TBI and was swapped when the old motor gave up the ghost), and a newly rebuilt 700R4 trans. The car drives great, but I have a few wiring conundrums I'm curious about. I've always been a Honda guy, (my other car is a 2007 Honda Fit... yeah I know.), so this carbed motor and mechanical transmission are totally alien to me.
First, my turn signals don't work. I have replaced all 4 bulbs, and they all light up, but they won't flash. I assume this means my signal flashing unit is dead, but where is this located? I'm assuming it's located under the dash near the fusebox, but I can't seem to find it.
Also, my tach and speedo don't work. According to the previous owner, they just need to be hooked up, as they were disconnected when the motor and trans were swapped and never reconnected. Where does the tach wire connect to, and furthermore where/what color is this wire?
From what I have learned, the speedo is more of a mechanical system. How would this hook up to my 700R4? What kind of adjustments would I need to make?
The previous owner told me that the rear diff was a positraction unit, but I've found I've got a "one tire fire" thing going on, so I have a feeling that the previous owner was wrong or the clutches are worn out.
Thanks for any help you can provide, I'm really excited to learn more about this car, I know I need to adjust the idle (the car will take off and even shift to 2nd gear without me ever touching the gas..) but I figured a working tach would be in order first.
Old Feb 1, 2008 | 04:27 PM
Re: New member, got some wiring ?'s
Anybody? I'm trying to get this car back into full working order. Doesn't anyone know about the tach/speedo on an 87?
Old Feb 2, 2008 | 04:31 PM
Honestly? Not even a flame because I'm a newb? Wow. That's pretty sorry. You all should be ashamed.
Old Feb 2, 2008 | 06:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
give it some time its a lot of questions
cant help with the turnsignals, never delt with them
tach wire connects to the dizzy, i think its a brown wire, connects next to the powers tail on a HEI, i dont know what the old owner used or did.
birds have an electric speedo, its a purple and a yellow wire. Should be hangin by the trans, and should have a plug on it. connects on the driverside near the rear of the trans.
as for the rear, only real way to know is to pop off the cover and take a look for yourself. Its probably due for a fluid change anyway
Old Feb 3, 2008 | 09:50 AM
Thanks alot, now at least I'll know what color wires I'm looking for.
I did a search and apparently the blinker flashing unit is somewhere behind what used to be my OBD port. I'll take a look this afternoon when I'm out changing my hatch struts.
Thanks again!
Last edited by Explosivpotato; Feb 3, 2008 at 09:59 AM. Reason: Because my sentance structure sucks.
1992 Trans Am
May 10, 2023 07:19 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
overdriv
Aug 20, 2015 03:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
