Cruise control problem
Old Jan 6, 2008 | 09:41 PM
84camaro84's Avatar
Engine: 5.0 H.O.
Transmission: 5-Speed
I am restoring my 84 Z28 and right now I am in the process of doing some rewiring (getting rid of the aftermarket alarm, radio, etc.). One thing I just remembered was about 5 years ago, I used the cruise control and it worked perfectly. The problem was when I applied the brake, instead of the cruise control shutting off, it decided to speed up so when I engaged the clutch, the RPM's rose up quickly and luckly I shut down the engine right before it red lined. Basically I never have used cruise control since then. Since I am rewiring the car, I figured I would fix the problem, the problem is I have NO idea where to start diagnosing. Anyone have ANY ideas or heard of this problem?
More about the car, it's a 1984 Z28 H.O., 5-speed.
Thanks,
Cory
Old Jan 6, 2008 | 10:18 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
Re: Cruise control problem
make sure the switches that touch the brake pedal arm are not stuck, look above the pedal, next I would change the cruse unit on the fender.
Old Jan 7, 2008 | 05:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following is from an 85, but it may prove useful:
http://www.geocities.com/vtcamaro/Pi...rams/pg254.jpg
JamesC
Old Jan 7, 2008 | 03:52 PM
84camaro84's Avatar
Engine: 5.0 H.O.
Thanks! I'll check those out and post my results
Old Jan 31, 2008 | 05:44 PM
84camaro84's Avatar
Engine: 5.0 H.O.
Something I just realized about the car. I forgot years ago there was a problem with the clutch safety switch, so my Dad actually removed it completely rather than replacing it. I know the safety switch prevents you from starting the car without pressing the clutch, but do you think it caused the problem stated above? (Not shutting down the cruise control)
Old Jan 31, 2008 | 09:28 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
There are two switches on the clutch, one in the full-down position for safe starting and one in the full-up position for the cruise control. If your father disabled the latter, that would prevent your cruise control from turning off when you depress the clutch pedal.
Lou
Old Jan 31, 2008 | 11:59 PM
Transmission: stock
hey BigBabyLou, I am colecting parts for my 86 Z28, I have a 4L80E that I am going to make full manual shift, that outa be a riot. especially arround 8500rpm, it should get quite interisting
Old Feb 2, 2008 | 11:14 PM
84camaro84's Avatar
Engine: 5.0 H.O.
Well I know I need one, but I don't know what it looks like so I can pull one out of a salvage. Does anyone have a picture they can send me of what a clutch safety switch looks like. I need it for my 84 Z28.
Old Feb 3, 2008 | 01:31 PM
BigBadLou's Avatar
Engine: TPI
For the cruise control to work right, you don't need the clutch safety switch, you need the cruise control disable switch.
It's the same as the brake (stop lamp) switch: http://www.partsamerica.com:80/Produ...tNumber=SLS101
If you do need the clutch safety switch, it looks like this: http://www.partsamerica.com:80/Produ...Number=NS36831
(you might need to punch in your zipcode to show the part)
Hope this helps.
Lou
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
