headlights question
Old Feb 8, 2008 | 12:02 AM
l2tofo's Avatar
headlights question
hello
i want to find out something about headlights...
im not a specialist in electronics and wiring.
and i want to know smth about 2 types of headlight lighting i saw
about camaro 3rd and prefacelift 4th gen.
these 2 cars have 2 rectangular headlights,same size and appearance and i think same bulb type???perhaps H7 or H3???
these are some pics i found.so these are the low beam lightind right?
(i care only about low and high beam)
and the second headlight is the high beam???am i right????
1)tell me please,whats the go with this last night shot?
both headlights are on.they seem to me they have the same brightness,so i guess they are both low beam and somehow they get brighter to become high beam?
2)in stock 3rd and 4th gen headlights,both 2 headlights have same bulb type?how does the high beam lights up more than low beam if they are same bulb and they are same headlights?its all about wiring maybe?
thanx a lot,and i know that more questions will come up
Old Feb 8, 2008 | 12:08 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: headlights question
The outboard lights are "dual-beam". They have two filiaments in them, one for low-beam and one for high-beam. When the low beams are on, only the low-beam filiament is lit. When the high beams are switched on, the low-beam filiament is turned off and the high-beam filiament is turned on. The inboard high-beam lights only have a single filiament that's only on when the high beams are turned on.
Old Feb 8, 2008 | 08:03 AM
l2tofo's Avatar
you are talking about the 4th picture only???
and you say that both lights used for low beam,and they become brighter when you hit high beam switch???
if you reply yes,i guess its someway like H4 bulbs,one bulb used for low and how beam
and if its like that,what is happening in the 3rd pic?its the same car and only one headlight is on.
maybe it is used as a marker light?and if you hit low beam,then both lights light up?
Old Feb 12, 2008 | 09:16 AM
l2tofo's Avatar
reply pls
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
