Mystery Boxes!
Old Feb 8, 2008 | 05:57 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Mystery Boxes!
i found some weird boxes i have no clue what they are.
i know one is the ECM since im running TBI.
im going to be running a Carb when i do my engine swap. which will be fairly soon.
i wont need the ECM. but im wondering about the other boxes. do i need them? what are they for?
here are the photos
this says pass key on it. what is a pass key?
Old Feb 8, 2008 | 07:01 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Mystery Boxes!
The pass-key box is part of the VATS system I think. In the second pic, the biggest one is the ECM...I assume you knew that. The other one...not sure. Where was it located? Over on the pass side near the ECM? It could be the body control module (BCM)... That would be my guess.
J.
Old Feb 8, 2008 | 08:04 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Mystery Boxes!
Yes, the black box is the VATS box.
If you're taking it out of the car completely, it helps to tape your old key to it. Or at least measure the resistance of the key pellet and put a post-it note on the box.
Can you take a picture of the sticker on the left metal box? What does it say?
Lou
Old Feb 8, 2008 | 01:38 PM
joshh44's Avatar
Engine: engineless
Re: Mystery Boxes!
what is a VAT system??
im going to be running my car for the stip only so do i really need it?
and also same with the pass key box?
i found some more little boxes im not to sure of.
i found one that was yellow and said sparkplug on it. i seem to missplaced that one. im not to sure where it is. is it nesseasary to have as well? ill try to find it.
i tryed to take some photos of the sticke on the 2nd biggest box. but keeps turning out all grainy and fuzzy. (cheap camera)
and yes it was located on the passeger side near the ECM.
here are the numbers on the box tho.
SERV. NO. 1228874
?11221 K191940878
16081221
||||||||||| (<--Barcode)
*AI1221k191940878*
thats what it says on the sticker on the 2nd box.
the question mark is i dont know. its to hard to read with that foam on there.
it eather a 1, or an I.
Old Feb 9, 2008 | 09:44 AM
BigBadLou's Avatar
Engine: TPI
Re: Mystery Boxes!
VATS = Vehicle Anti-Theft System
It is tied to the ECM and the ignition cylinder. If somebody tries to start your car without the right key (with a screwdriver, let's say), the car won't start.
If you're getting completely rid of the ECM, you don't need the VATS box then.
The 1228874 number on the smaller metal box indicates that it's the airbag module. You might want to keep it if you're keeping your steering wheel.
Hope this helps.
Lou
Old Feb 9, 2008 | 04:32 PM
joshh44's Avatar
Engine: engineless
Re: Mystery Boxes!
hey thanks so much for the info!
i wasnt sure what to do if i was going to screw up the electrial if i removed anything.
thank you
Old Feb 21, 2010 | 09:09 PM
Project-RS's Avatar
Re: Mystery Boxes!
there should also be another box under the dash. it has the letters AC on it. if your not sure what it is, its for cruise control.
Old Feb 22, 2010 | 06:45 AM
Car: 86 Trans AM
Re: Mystery Boxes!
Haha I think we need to make the year in bold or larger than the rest of the post date. Any way to make that happen admin??
J.
Old Feb 22, 2010 | 07:57 AM
Jeffs82TA's Avatar
Re: Mystery Boxes!
it's the DERM
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
Gordonr1973
Sep 29, 2015 11:59 AM
Zell1luk
Sep 29, 2015 10:36 AM
