wiring harness
Old Feb 11, 2008 | 09:27 PM
92WhiteZ28's Avatar
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
wiring harness
ok, so i tore the old wiring harness out of my iroc because it had missing/damaged connectors when i bought it, and went to the J-yard to pick up replacement connectors and everything, anyways i got the harness all repaired and lookin good, but then found two wires on the harness (one tan and the other purple *or pink*) and cannot figure out what they are for. ive studied the wire diagram for about two hours total trying to figure it out and just dont see it. the car is a 87 iroc with the 5.0 TPI. the two wires are coming out at about the same place as the IAC connector, and look like they were cut right next to eachother (they are the same length) any help would be greatly appreciated. I had a local member (Birdtojag) look at it and he cant find it either.
Old Feb 12, 2008 | 10:05 PM
92WhiteZ28's Avatar
Re: wiring harness
no one has any idea?
Old Feb 14, 2008 | 07:16 PM
sikZ28's Avatar
Car: 86 Trans Am
Re: wiring harness
are the two wires in question on your old harness or is this a completely different harness?
Old Feb 14, 2008 | 08:54 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: wiring harness
i have the carb 87 and remember a pair of tan and a second wires not used on my car. compared my car to a 87 tpi and IIRC on that guys car those go to the stock air cleaner assembly for some kind of sensor in the air cleaner body.
Old Feb 14, 2008 | 09:18 PM
92WhiteZ28's Avatar
Re: wiring harness
i havnt switched the harness, im only working with one. i took it out of the car so i could better repair it with new connectors and whatnot, rather than having to squeeze into the engine bay and do it like that. im getting ready to put the harness back in and will probably figure out where the wires go when i do that, who knows, maybe they are just grounds.
Old Feb 15, 2008 | 08:41 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: wiring harness
is there a place to plug them into the air cleaner?
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
