Turn signal wont disengage
Old Feb 17, 2008 | 08:56 PM
Saevelland's Avatar
Car: Trans am
Engine: 305 tbi
MY left turn signal wont auto disengage. You know when you turn the wheel then when it turns back the signal cuts off by it self. Its not a big problem just a minor annoyance and i would like to know why it wont so i can fix it.
Old Feb 17, 2008 | 10:41 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Turn signal wont disengage
There is a canceling cam in the steering column. You need to remove the wheel to be able to replace it.
Old Feb 17, 2008 | 11:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Do you need to replace the turn signal arm or can you just replace the cam? Dealership part?
This just broke on me the other day in my DD car. Unfortunately the air bag makes this a bit more tricky i'd think...
Old Feb 17, 2008 | 11:37 PM
Al Hasse's Avatar
Couldn't say how to do a 3rd gen one, except that the steering wheel needs to be removed. The only one I ever did was on a Cutlass in the mid 80's. I can't remember for sure, but I don't think the blinker stem needs to be removed. NAPA carries the part.
For tilt wheel
http://www.napaonline.com/MasterPage...nal+Cancel+Cam
For non tilt wheel
Old Feb 18, 2008 | 12:24 AM
Sonix's Avatar
Car: 1982 Trans-Am
Wow, that's easy! Thanks AL !!!
Old Feb 18, 2008 | 01:22 PM
Saevelland's Avatar
Car: Trans am
Engine: 305 tbi
Thank you. I guessed it was something like that.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
