power dies tranny goes wont crank
Car: 1987 Z28
Engine: 355
just had a new engine put in my car by a shop and the car ran great for about 4 hours and then the lights started to dim in the car and the windows stoped working. I lost all power and couldnt crank the car over. around the same time my car stoped going into 3rd gear and wouldnt go over 40-45 mph. Is the electrical problem due to a ground, bad altenater, or a bad battery. Also i want to know if the tranny problem could be related to the electrical problem at all? thanks
-Chris
-Chris
Car: 2000 SS, M6
Engine: Modified LS1
Re: power dies tranny goes wont crank
The first thing I would check are the connections to the alternator.
Second, check the voltage at the battery with the engine off, and with
the engine on. If the meter doesn't read about 14.0 VDC with the engine
running, there is something wrong with the charging circuit.
Car: 1982 Pontiac Trans Am
Engine: 305 V8
Transmission: TH200
sounds a lot like the alternator, did you install a new one? or used the old one? its most likely the alternator has gone bad or its a bad connection......
ambainb
Apr 25, 2016 09:21 PM
Zachattack0925
Aug 12, 2015 09:52 PM
