gauge cluster repin
Old Mar 13, 2008 | 08:14 AM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
gauge cluster repin
Has anyone just repinned their stock gauge cluster harness to work with a 140mph speedo? Does anyone have a pic of their harness plug from their 140mph speedo? It can't be that hard. In the middle of a lt1 swap so I don't need a vss buffer box. If someone could tell me what colors go where across the top and across the bottom that would be a huge help.
Old Mar 13, 2008 | 07:59 PM
rdog30's Avatar
Car: 85&95 Trans am
Re: gauge cluster repin
Anyone?
Old Feb 9, 2011 | 09:31 AM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
Doing the same sway now, not sure how your's went. Was curious to find out though.
Old Feb 9, 2011 | 06:58 PM
rdog30's Avatar
Car: 85&95 Trans am
I got it to work, but it's been a long time since I did. I ended up buying some connectors out of a 88 car and just repinned mine to match.
Old Feb 13, 2011 | 10:04 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
Did you ever or do you have still a copy of the 82-85 style cluster pinouts? Trying to figure out some serious wiring issues...
Old Feb 15, 2011 | 10:34 PM
rdog30's Avatar
Car: 85&95 Trans am
Not sure if 82-84 are the same as 85. I just followed the basic diagram for 86-92 gauges. I do remember that each connector needs a power souce as my 85 harness only one of the connectors had power with the key on.
Old Feb 17, 2011 | 12:05 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Look in this thread.......
https://www.thirdgen.org/forums/elec...d-cluster.html
Old Feb 2, 2012 | 09:29 AM
Wormdog13's Avatar
Car: 1986 Trans am
Engine: tuned port 305 LB9
Axle/Gears: .323
hey did you ever figure out your wiring issues or find a diagram?? Because I also have a wiring issue. Previous owner hacked it to $h!t.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
