Speedo Gremlin...
Old Mar 13, 2008 | 06:27 PM
400HP88IROCCONV's Avatar
Car: 2007 R/T-R package CHARGER!
Speedo Gremlin...
So here's the scoup:
I replaced the Headlamp switch with a new one, & I also replaced the Wacky-tach with a new old stock one. Enerything works fine until I turn the headlights on. After a few minutes all of the gauges except the speedo freak out & peg all the way up or down. Also- the right turn signal indicator illuminates. If I twist the dimmer I can get partial recovery, but nothing works right until after I turn the headlamp switch off. Then everything works again.
WTF?
Old Mar 16, 2008 | 05:36 PM
Re: Speedo Gremlin...
So uh...., bump.
No quick fixes for this one huh?
Old Mar 21, 2008 | 08:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If all functioned correctly before the switch install, then reason would suggest that's the place to start.
JamesC
Old Mar 21, 2008 | 11:56 AM
This problem is the reason I replaced the headlamp switch in the first place. I thought it was a problem with the dimmer reastat(sp?) because when the dash would crash I could get partial recovery by twisting the dimmer. If I turn the dimmer all the way down I get almost total recovery. When I turn the headlamp switch completely off the cluster recovers completely.
Since replacing the headlamp switch the only improvement is smoother dimming. The pre-existing problem with the dash is the same as before.
Here's one thing for thought: The brighter the dimmer setting, the more out-of-whack the gauges are???
Old Mar 21, 2008 | 12:12 PM
JamesC's Avatar
I have no experience with your particular problem, but perhaps the following will be helpful:
http://92b4crs.tripod.com/86wiring/dia-pics/117-0.jpga
Here's the entire link to the above:
http://92b4crs.tripod.com/86wiring/86wiringindex.html
Here's yet another link:
http://www.austinthirdgen.org/index.php?pid=19
JamesC
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
