steering column problem
Old Mar 15, 2008 | 12:53 PM
z1colt45's Avatar
Car: 1990 Firebird Formula
Engine: 305 TBI
I just had my starter replaced last week and since then everthing was good until yesterday when the car wouldnt start again. Assuming the starter was bad i had it towed back to the shop where the starter was replaced so they could fix their own work. Today they called and said the car will start if you play with the steering column a bit i.e. move it around, adjust the tilt. What could be some possible causes of this?
Old Mar 15, 2008 | 03:43 PM
colbear92rs's Avatar
Car: 92 rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
Re: steering column problem
well i had a problem like this, my car wouldnt start up some times when i messed with the tilt on the colum, and some times my car would die, when i hit a bumb or something, it endened up being my lock cylinder, where u put ur keys in to turn the car over, there are two wires coming out of the cylinder, one of them on my car was cut.......try checking that
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 23, 2015 06:33 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
