where does this come into the car?
Old Mar 17, 2008 | 05:27 PM
Booda_33's Avatar
Car: 1982 Trans Am
Engine: Junk 305
i have been trying to track down where the pink wire from the fuel gauge sending unit comes into the instrument panel. im tired of runing out of gas...lol
Old Mar 19, 2008 | 02:56 AM
j_camaro_67's Avatar
Car: dark hunter red 84 camaro
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
Re: where does this come into the car?
i will be able to tell you later today when i go work on my camaro, its right apart because i'm getting rid of all the wire's not needed and swaping in auto meter gauges.
Old Mar 19, 2008 | 09:44 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
It runs from the gas tank, through the metal behind the rear seats, under the carpet and up to the dash.
Hope this helps.
Lou
Old Mar 19, 2008 | 10:23 AM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
it runs from fuel tank along the rear frame rail. then enters the car by the back bumer tail-light area. then its mixed with the tail light harness and runs under rear 1/4 panel interior plastic then under the door sills. If you remove the drivers kick panel you'll see the connector to the dash harness (will be a connector with yellow, green, brown and a few other colors, last I remember it was a white rectangle shape connector) from there it goes to the instrument cluster ................... Bigbabylou the ones that entered the car behind the seats was later models 82-at least 84 entered where the tail light harness did.
Old Mar 19, 2008 | 10:36 AM
BigBadLou's Avatar
Engine: TPI
Ah, I see. Thanks for the correction. I know more about the 86+ cars.
Lou
Old Mar 21, 2008 | 05:06 PM
Booda_33's Avatar
Car: 1982 Trans Am
Engine: Junk 305
thanks guys...almost ready for the track.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
