Shift Indicator Light
Old Mar 19, 2008 | 10:33 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
When I bought the car the light didn't work and so when I cleaned underneath of there for cig ashes and stuff I found out that the light bulb shattered somehow. I got a 194 replacement bulb and it does not work. I tried it both ways just in case. Any ideas of why it wouldn't be lighting up?
Old Mar 19, 2008 | 10:58 PM
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
Re: Shift Indicator Light
The socket itself might be burnt up or damaged. Mine didn't work either when I bought my car. But the bulb was merely burnt out. However the socket is pretty dry and cracked from the heat.
Old Mar 20, 2008 | 03:55 PM
robster66's Avatar
Engine: 305 T.B.I.
I could just test it with a multimeter right?
Old Mar 20, 2008 | 04:23 PM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
Just a thought .... maybe cause you have a automatic is why it wont work
Old Mar 20, 2008 | 07:31 PM
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
I'm pretty sure he means the indicator on the floor. The "P R N OD D 1 2" shifter since he was cleaning cig ashes. . .Mine was a damn mess too.
As for the test, I've never done it before. . . But I guess you could. Also check the wires. . . someone might of hacked into it.
Thornburg
Aug 25, 2015 01:46 AM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
