alternator wiring qustions
Old Mar 21, 2008 | 08:47 PM
Parts4sale's Avatar
<-- i have one like this what is with the black conneter in this pic on the back of the alterator? do i need it? i swaped to a carb setup and gutted most my wires, can i jsut run a single wire to the BAT with out runing the other wires beslides ground, what is that plug for on the back of the alternater anyways? any help would be great thanks i looked in my repair book and didnt find anything explaning what that other connation was for
Old Mar 22, 2008 | 12:18 AM
Parts4sale's Avatar
Re: alternator wiring qustions
bump
Old Mar 22, 2008 | 10:59 PM
Parts4sale's Avatar
bump
Old Mar 22, 2008 | 11:47 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
https://www.thirdgen.org/forums/search.php?do=process
Old Mar 23, 2008 | 01:55 PM
Parts4sale's Avatar
Your a jerk! i wouldnt have posted if i found it on a search its to complcated of a qustion to search with and i cant find the anser for here nor on the web so this is why i posted
bump
Last edited by Parts4sale; Mar 23, 2008 at 01:58 PM. Reason: Automerged Doublepost
Old Mar 25, 2008 | 12:24 AM
Parts4sale's Avatar
bump
Old Mar 25, 2008 | 12:58 AM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
I think the red wire controls the voltage regulator and brown goes to the voltage gauge and black which mine doesn't have so not sure why your plug has would be more then likely a ground. The lug on the back of the alternator is obviously the charging wire .... Hope that helps.
Old Mar 25, 2008 | 09:22 AM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
If I remember correctly one wires sends a signal to the voltage gauge in the car. I know the brown wire runs to the fan fuse so the alternator can increase its output under the additional load and the heavier of the 3 runs somewhere behind the dash to the main hot bus if I remember correctly. It's been a while since I looked at my GM electrical manual
Old Mar 31, 2008 | 03:59 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
so when purchasing an alternator from like summit or somewhere and they say whether or not the unit is one wire capable... would you need it to say yes or no? for example
this one isnt
http://store.summitracing.com/partde...5&autoview=sku
and this one is
which one would you buy? if you have the plug and battery wire then do you need the one that isnt one wire capable?
Old Mar 31, 2008 | 04:26 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Get the one that is one wire capable, and run it just to the battery, good to go
Old Mar 31, 2008 | 04:30 PM
i just looked and the plug on mine runs through the injector set up so i dont think i can not have it. so does one wire mean then that there is no plug on the back just a battery wire?
Old Mar 31, 2008 | 04:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Correct. Mostly.
Some alternator models still have the two prong plug, but its plugged off with a rubber insert.
Old Mar 31, 2008 | 04:44 PM
so then i will just get the one that isnt to make sure the plug is there. thanks for you help
thread unhijacked!
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
