plz help 1986 hatch pull down wires
Old Mar 23, 2008 | 01:18 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
can someone plz tell me where the 2 wires in the attached pics plug in to?
Attached Thumbnails plz help 1986 hatch pull down wires-dscf3802.jpg   plz help 1986 hatch pull down wires-dscf3803.jpg
Old Mar 23, 2008 | 01:45 PM
Uljas's Avatar
Car: GTA
Engine: 350 tpi
Transmission: th700
Re: plz help 1986 hatch pull down wires
Hi the one on the right with 4 pins plugs in to the reversing switch witch is attached to the pulldown motor.
Old Mar 23, 2008 | 02:32 PM
Car: 1986 IROC-Z28
ok the one on the right is taken care of. any ideas on the left?
Old Mar 23, 2008 | 04:19 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It is unused on your year of car. It was used on 1989-91 cars to turn on and off the rear hatch light. Your car has a manual switch. The later model years I already mentioned have that white wire plugged into a tan with white stripe wire. The wire switched off ground to the hatch light. If you want you can hook the ground of your hatch light to that white wire and the hatch light will be turned on and off automatically by the striker-sensing switch of the pull-down motor.
Lon
Old Mar 23, 2008 | 04:54 PM
Car: 1986 IROC-Z28
thanx man i got the whole hatch pull down assembly working like new now
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
