Power Lock Woes
Old Mar 25, 2008 | 09:20 PM
Artic White's Avatar
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Power Lock Woes
Okay so I have a keyless entry/alarm installed and my power door locks will only engage partly.
When I hit lock on the remote since my interior buttons do not work, they will engage slightly still allowing me to open the door.
The same goes for the unlock as well.
The only switch that works on the inside is the unlock side of the drivers side switch.
I took off the driver side door panel and tried to lube up everything really well but it still is the same thing.
Does anyone have any suggestions?
Old Mar 26, 2008 | 02:37 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Power Lock Woes
lube up some more! I though I was going to have to replace my power door lock actuator when I installed my keyless entry, but I lubed every moving part in the locking mechanisms. I squirted some WD-40 inside the little boot of the actuator and all along the shafts... Thats all I can think of, anything else is replacing the actuators with new ones...
Old Mar 26, 2008 | 12:47 PM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Re: Power Lock Woes
Thank you. I'm going to try that soon. If that doesn't work what is the cost and how hard would it be to replace the actuator?
Old Mar 27, 2008 | 12:48 AM
HCR13's Avatar
Car: 1987 Trans Am
Re: Power Lock Woes
the cost varies. I got one of my actuators from the junkyard (like $1, $2?). I took a 14.4v drill and used the battery to quickly test to see if it worked... The "hardest part" is removing the actuator from the donor car since its riveted in place. I used a combination of pliers, drill bits, and screwdrivers to pry it off (those rivets are stubborn). Once you get it off, its pretty simple... I'd say no more than 40mins to securely install a new one. If you go the jk route, I'd practice safely removing the plastic poprivets from the donor door panel (so you don't damage yours)... New actuators can be had too, but I'm not sure the price or p/n's for those...
upon installation, you can just bolt the actuator in...
Old Mar 27, 2008 | 09:50 AM
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Re: Power Lock Woes
Thank you very much for the help. I need to get some time to open up my door panel again and go for it!
Old Mar 28, 2008 | 03:50 AM
HCR13's Avatar
Car: 1987 Trans Am
Re: Power Lock Woes
all you need is some torx screws and a flathead screwdriver...nothing to it!
Old Mar 31, 2008 | 03:53 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: Power Lock Woes
look on ebay for new ones if thats what you want. thats where i bought mine. you can get new old stock $20 or new new for like $36. and lube the heck out of all the parts in your door
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
