vats question
Old Mar 29, 2008 | 03:09 PM
demon79's Avatar
Car: 1983 firebird
Engine: 350 lt-1 crate motor
Transmission: borg warner t-5
Axle/Gears: stock 3.27 posi rear disk
vats question
can I bypass the vats system on an 89' formula 350?if so what do I need to do it?
Old Mar 29, 2008 | 04:42 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: vats question
there is a tech article about how to do it.
Basically you just need to know the resistance in your key and then between the ignition and the vats pass key box put that level of resistance in the wire to fool the system.
Also if you ever need a custom chip burned you can disable it that way also.
stalkier
Dec 6, 2015 11:25 PM
WIzmo
Aug 30, 2015 02:30 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
