Power antenna problem
Old Apr 5, 2008 | 01:35 AM
usdsk8er540's Avatar
Car: 01 Silverado & 84 Camaro Z28
Engine: Truck-5.3L Vortec V8 Camaro-427 BBC
Transmission: Truck-Auto Camaro-Borg Warner 5-spd
Axle/Gears: Truck-??? Camaro-stock 3.73
hey yall. well i have some questions. i have an 84 camaro z28 with what i assume is a power antenna (either that or you can just adjust how long it is! lol) but the power antenna is not working. i have to pull it up or push it down. first question, is my power antenna not working because it has had a big block swap (427 carbed) and doesnt have all the electronics that went with the original motor or is the antenna motor burnt out? it has the original radio in it (am/fm casette) and it works fine. i would assume that even with the big block swap the radio would have an antenna lead that triggers the antenna to extend when it powers on (kind of like the antenna lead for an amplifier for a stereo system). second question is, if the antenna motor has burnt out, how do i get to the motor and where can i get a new one? any help on this would be greatly appreciated. thanks yall!
Old Apr 5, 2008 | 06:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Power antenna problem
The relay is under the dash, pass side. Remove the pass tire and the plastic inner fender panel. There's a kit available should the problem be the mast itself. I think that GM has discontinued the OE antenna, but there are various universal kits around.
JamesC
Old Apr 6, 2008 | 10:38 PM
thanks for the info james. by the way, if the relay is burnt out, how can i tell other than putting a new one in and trying it? also, would it be any easier to just do away with the power antenna and just do a fixed one? i dont know what has been done to the wiring in my camaro since i just got it a few months ago before my dad went to iraq and it already had the big block swap done to it. i guess the main problems with it are the speedo and gas gauge dont work (speedo is in the gear in the tranny i believe and the gas gauge is in the sending unit, hopefully dont have to replace it) so the power antenna is the least of my worries, but it would be nice if it worked. thanks again james. i appreciate it.
Old Apr 7, 2008 | 05:31 AM
JamesC's Avatar
The relay should "click" when you turn the radio on. Swapping to a fixed mast shouldn't be a particular problem and it would probably be cheaper in the end. Your 84 should have a mechanical speedo, so I'd check the cable itself. A search will provide the info you'd need to determine whether you need sender or gauge.
JamesC
Old Apr 14, 2008 | 06:16 AM
tanker's Avatar
to change the ant motor u need to pull the fender its a bitch for a pita problem
Old Apr 16, 2008 | 04:40 PM
docs89gta's Avatar
Car: 89 GTA Trans Am
Actually it's not that much of a pain. If it's in the front passenger's fender like mine, which i'm sure it is, it's not that bad. Mine had gone out and i bought a universal antenna and realized it won't fit. The power antenna's in our cars have what i call a remote motor then flexible tube to the mast. The only place i found one was at JcWhitney. Here's a link.....
http://www.jcwhitney.com/AM-FM-RADIO...0501_10101.jcw
I haven't had any problems since getting this antenna. The hardest part was getting the antenna line into the car thru the firewall. Other then that, it wasn't that bad of a job. Hope this helps.
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
Bert87
Aug 23, 2015 03:50 PM
db057
Aug 22, 2015 08:17 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
