Cannot figure out charging problem.
Old Apr 7, 2008 | 09:02 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I've had this car for about 4 years already and since day 1 when it was bone stock it has always had a charging problem. We converted the TBI to an 89 MAF system and TPI. Still a problem. We converted a brand new OBD 2 harness which gets rid of darn near everything and we still have the problem.
As soon as car starts it charges good. After about 10 minutes the voltage gauge takes a dive. Usually between 9-11 volts it shows. Everytime I hit the brakes it drops or everytime the blinker goes it drops. I have thrown on 3 new alternators, (105 amps) new power cable, new negative cable, 3 brand new fusable links, cleaned all terminals and grounding location on the head. new wire between alternator and battery. When we take it to autozone and thrown on their machine, it states that its putting out 14.45 Volts but very low 53-55 amps when load tested. When it was load tested the gauge went into the red. I am at a total loss. Its done this with 3 differant batteries as well. Current batt is a Yellow Top optima. There doesnt seem to be an abnormal draw as the battery in the car sat all winter and the battery still had power 6 months later. Not enought to start it, but it had power.
Only add on is a 6AL box. No pulleys. Stock still
Any help would be appreciated. Car is 2nd in sig.
Old Apr 8, 2008 | 03:28 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Cannot figure out charging problem.
sounds like u have a bad altenator.. low amps ftl. have a new one load tested before u walk out the door.. some new/and or reman altenators test good at the factory but fail at the parts stores..
Old Apr 8, 2008 | 12:43 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I thought about that, but I took the alt off the formula which is good and it had the same effects on the Camaro.
Old Apr 8, 2008 | 01:09 PM
camarokracker's Avatar
Car: 86 Camaro Sport Coupe
Engine: 377 sbc
Transmission: WC T-5
Axle/Gears: 3:70 Ford 9" Rear
try checking the feed wire from the alt to the battery.. i had the same problem and found out it was the feed wire.... It was old and had a few bad strands inside..
Old Apr 8, 2008 | 02:30 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Brand New.
Old Apr 8, 2008 | 03:16 PM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
Check your engine to body ground strap. If the 10mm bolt that secures this strap to the firewall is loose they will do this. Also make sure its tight on the back of the block.
Old Apr 8, 2008 | 07:11 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
New taylor strap, body wire wheeled where it connects. Good bare steel on block.
Old Apr 9, 2008 | 11:16 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Follow the red power wires from the starter that pass through the C100 firewall connector and then goes to light switch, fuse box, and ignition switch. Somewhere along that route you should find the voltage drop.
db057
Apr 28, 2019 07:45 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
customblackbird
Oct 1, 2015 04:30 PM
Johnoooooo
Sep 22, 2015 08:55 AM
383cam
Sep 9, 2015 06:01 AM
