Help with Tach
Old Apr 9, 2008 | 09:38 AM
marolover30587's Avatar
Car: 87 camaro
Engine: 305, Stock?
Help with Tach
Hey my tach doesnt work can anyone tell me what wires go to the distributor. There are two wires that go there with only one flat connector empty. Not a big deal but would like it to work.
Old Apr 11, 2008 | 08:03 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: Help with Tach
Tach wire plugs directly into the condenser (little cylinder, size of your thumb. see pic.)that is bolted (1 bolt) to the firewall behind the distributor. The wire off the condenser plugs directly into the drivers side of distributor cap.
https://www.thirdgen.org/forums/atta...dstate-lea.gif
Old Apr 14, 2008 | 09:22 AM
Car: 87 camaro
Engine: 305, Stock?
Re: Help with Tach
Thanks Ill look around and see if thats the problem.
Old Apr 14, 2008 | 09:39 AM
Ep1nephr1ne's Avatar
Re: Help with Tach
check the obvious, clean the connector, make sure the wires are not loose, put some conductive lube on it.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
