headlights keep turning off on the road
Old Apr 12, 2008 | 08:56 AM
87whtiroc's Avatar
Car: 87 iroc
Engine: 350 tpi
Transmission: 5spd husrt shift kit
ive had this problem almost every time that i take my 87 iroc out. it usually happens around an hour after i leave but has started to happen in less time. ill be driving and the headlights flicker a couple times then shut off completely and i have to pull over. after i pull over for a couple minutes with the lights off i turn them back on and they work again. also the high beams only light up the headlights brighter the two lights in the middle do nothing. i just wanted to know if anyone knows what might be wrong. i have the chilton book and a knack for taking things apart but a little help in locating the problem always helps. if anyone can help please reply
Old Apr 12, 2008 | 08:22 PM
jvontungeln's Avatar
Car: 83 Camaro
Axle/Gears: 342's
Re: headlights keep turning off on the road
Go buy yourself a new switch. The headlamp switch has a built in relay to protect it from an overcurrent situation, when the relay begins to fail they begin to flash.
Derick15
Sep 17, 2016 05:28 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
