wierd battery dying
Old Apr 17, 2008 | 04:55 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
wierd battery dying
ok, i can start my car right up in the morning, but then i'll shut it off and then try to start it and the battery is dead? new alt. new starter, new battery. another thing it runs differently everytime i start it? everything is new on this car. all the sensors, everything! ecm(ecu) is also brand new not rebuilt. and my fan still isn't coming on .
Old Apr 17, 2008 | 07:02 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: wierd battery dying
Does the lights in the dash also go dead?
What's the issue about the fan?
Any other accessory problems?
Running different?
Describe..
Old Apr 17, 2008 | 12:34 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
lights stay on. fan just don't come on. one time it runs like a stripped a** ape then the next time i start it stumbles all over itself. it is a brand new jasper 305 and i put everything new on this car / motor. i think it is just jinxed!
Old Apr 18, 2008 | 01:29 AM
Ok, the lights staying on while it refuses to crank obviously means it isn't the battery, it's a starter or a wiring issue.
Fan; does the car ever overheat? Do you have A/C? What t-stat do you run?
No offense, but I think the jinx is hiding in the lack of attention to detail & reasoning.
Old Apr 18, 2008 | 06:17 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i am guessing its over heating because radiator starts steaming. do not know what t- stat is in it.
Old Apr 18, 2008 | 12:43 PM
Ok, so that's what's up. It might not neccessarily be overheating because if the cap is not able to keep the pressure in then the water will boil prematurely, perhaps even before it reaches the temperature that the fan is set to turn on at. Check or replace cap, and if that fails then try to get a temperature measurement. The fan has a relay. Grounding the control wire should turn it on. Do a search to find a wiring diagram. If you can get a log (or a scan) done on the ECM while the engine is running, it should also tell you if the ECM actually measures the actual temperature, plus other operating parameters. Maybe there's something wrong with the temp sensor for the ECM.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
z28joe2
Sep 28, 2015 05:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
andy74
Sep 3, 2015 08:41 AM
