cooling fan
Old Apr 20, 2008 | 12:07 PM
sinisterrs's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0
Axle/Gears: 2.73's
cooling fan
My cooling is not working and i pull the relays not sure which one is for the fan but one the plugs is burned so i was thinking that maybe this supplied power to fan ...... fuse is good
Old Apr 23, 2008 | 08:23 PM
sinisterrs's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0
Axle/Gears: 2.73's
Re: cooling fan
BUMP
Old Apr 27, 2008 | 03:37 AM
zed's Avatar
zed
Car: 1991 Z28, 1984 Z28, 1990 Toyota 4x4
Engine: L98, L69, 22RE
Transmission: 700R4, 700R4, 5Speed Manual
Axle/Gears: 3.73, 3.23 Posi, 4.10
Re: cooling fan
do you have a question, or are you just telling us this info for some reason?
Old Apr 27, 2008 | 10:13 AM
sinisterrs's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0
Axle/Gears: 2.73's
Re: cooling fan
does that terminal on the plug feed power to the cooling fan?.... the burnt one
Old Apr 27, 2008 | 11:12 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: cooling fan
Can't tell from just looking at the plug, they all look alike (pun intended).
What wire colors go into this one? That will tell you whether it's the fan relay.
Lou
Old Apr 27, 2008 | 11:30 AM
sinisterrs's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0
Axle/Gears: 2.73's
Re: cooling fan
the car is in the tranny shop so not sure about the colors but i do know that this plugs has a empty terminal to the left of the burnt one but the other relay plug uses all 5
Old Apr 29, 2008 | 08:30 PM
sinisterrs's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0
Axle/Gears: 2.73's
Re: cooling fan
bump
Old Apr 30, 2008 | 09:45 AM
BigBadLou's Avatar
Engine: TPI
Re: cooling fan
Why are you bumping? You haven't told us the wire colors yet. *shrug*
Lou
EDIT: Well, thinking about it, if you have ONLY TWO relays and the other one has 5 wires, than this one most likely is your fan relay.
When you get your car back, you can take a paperclip and short the two BIG terminals in the plug and see if your fan comes on.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
