oil pressure gauge
Old Apr 20, 2008 | 06:22 PM
sinisterrs's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0
Axle/Gears: 2.73's
oil pressure gauge
i just bought this car two weeks ago and the oil pressure gauge stays pegged out all the way to the right.... any suggestions
Old Apr 20, 2008 | 08:28 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: oil pressure gauge
Check the wire on the oil sender. It looks like the first pic, and is located at the back of the engine in the second pic.
Attached Thumbnails oil pressure gauge-oil-sender.jpg   oil pressure gauge-oilsenderlocation.jpg
Old Apr 20, 2008 | 08:40 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
He's right, check the oil pressure sender connector. If the gauge is pegged, that means there is a break in the circuit.
Although, I thought that all the 90+ engines had the oil pressure sensor and switch in one unit attached to the engine just above the oil filter (accessible from underneath the car). Am I wrong?
Lou
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
