No power to fuel pump relay
Old Apr 21, 2008 | 02:44 AM
onebadta's Avatar
Car: 89 GTA
Engine: 383, Accel DFI, stealth ram
Transmission: 700r4, 3500 stall
Axle/Gears: 9 bolt 370 gears
Hey guys I just bought a 90 model GTA that had been sitting for atleast a year.. but anywho.. turn key on.. no fuel pump prime.. i unplugged the fuel pump relay and the only wire thats hot is the Orange wire.. nothing on anything else.. already checked the fuses.. thanks for any
Old Apr 21, 2008 | 09:36 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: No power to fuel pump relay
Try this troubleshooting link:
http://www.austinthirdgen.org/index.php?pid=35
Hope it helps.
Lou
Old Apr 22, 2008 | 04:42 AM
onebadta's Avatar
Car: 89 GTA
Well I think I found it.. I'm now getting my 2 second purg signal from the ECM.. odd it wasnt there before.. anywho.. fuel pump i do belive is fried.. was getting very little ohms from fuel pump pos + to ground -.. now not getting anything.. checked plugs in between.. all looks good.. no HUMM or anything if i jump from (+) to Fuel pump wire.. i suppose i'll soon be pulling my rearend then anyone know of a place for the best deal on a 255LPH pump?
Old Apr 22, 2008 | 09:11 AM
BigBadLou's Avatar
Engine: TPI
Before you drop the tank, have you checked the C313 as the tech article recommends? Many cars have a bad connection there and once cleaned, the pump usually works ok. If it's just an oxidized C313, you won't have to drop the rear axle and tank. Just trying to save you unnecessary labor.
Lou
Old May 8, 2008 | 11:08 PM
gta90's Avatar
Car: 1990 GTA (T-Top)
Engine: 305 TPI (LB9) / 115k miles
Transmission: 4L60 (MD8 non-E)
Axle/Gears: 2.73 (GU2) 28 spline POSI (G80)
my fuel pump may be fried as well. i can't seem to locate the fuel pump fuse. the service manual says it should be there (there's even a picture), but it isn't there on my model. Any ideas? The car is a 1990 GTA 305.
forgot to ask... what is a C313? Where is it located?
Old May 8, 2008 | 11:48 PM
gta90's Avatar
i found a fuse just off the battery terminal, which i think is the fuel pump fuse. The fuse appears to be fine.
Old May 9, 2008 | 08:47 AM
BigBadLou's Avatar
Engine: TPI
Did you also forget to read the troubleshooting article mentioned above?
It tells you exactly where the C313 is and how to get to it and test it.
Lou
Old May 10, 2008 | 03:16 AM
tripingeorge3's Avatar
make u a fused jumper wire . pull down the back seat . plice into full pump wire . should work. if not check ground wire located in same place, make sure its grounded but usually if u have a bad ground your full gauge jumps to full
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Kaweh
Aug 9, 2015 02:54 PM
