Cars wont start
Old May 6, 2008 | 09:56 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
Cars wont start
I just baught 2 v6 firebirds both suffering with the same problem.
one is an 90 and the seconds one is a 95. The problem is when i go to turn the key nothing happens, security light blinks at me non-stop. Ive done some digging in the 95s wiring harness found an old viper alarm and spme bad fuses, all of which has been removed and replaced. Still nothing. I jumped a hot wire of the battery into the starter while spraying carb cleaner in the intake and started up just fine aslong as the carb cleaner was there...then it died again.
I havnt started trying to fix the 90 yet, in the cause i dont want to spend a crap load of money on it to find out everything i replace is fine. I seem to do that on my 92 camaro as is <<;;
any suggestions?
Old May 6, 2008 | 10:07 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: Cars wont start
Do the keys for these cars have the VATS chips on them? I wonder if that's the key to the problem? Occasionally if my key gets dirty, thats what happens, and it won't start until i clean it off. I doubt your problem is that easy to fix, but I'd suspect it may be something with that.
Old May 7, 2008 | 03:31 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
Re: Cars wont start
plugged a scanner in for codes, dropped 1
Code 46 Passkey 2 error
what exactly is that?
Old May 7, 2008 | 03:35 PM
campin1983's Avatar
Re: Cars wont start
Yep, thats VATS. The key you are putting in doesn't match what the car was set for, so it won't start.
Old May 8, 2008 | 03:38 AM
karl's-92'-z28's Avatar
Car: Too many cars
Re: Cars wont start
Yup try cleaning that little looking chip on the key.
Old May 8, 2008 | 10:26 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
Re: Cars wont start
i got a vats/passkey 2 bypass module but i dont quite understand what im wiring it into...help!!!
Old May 10, 2008 | 10:12 PM
tripingeorge3's Avatar
Re: Cars wont start
theres 2 white wires running from your ignition lock down under your steering column.those are the 2 wires that touch both sides of the chip on your key. you'd cut those wires under the column and connect your bypass to that
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
