speedometer problem
Old May 9, 2008 | 08:53 AM
gibsongod716's Avatar
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
speedometer problem
hey i have an 85 trans am with a mech speedometer and i ordered a tranny swap that came with a 92 W/C tranny with a electric speedometer sending unit, i was wondering wat parts i need and wat to do to make an electric speedometer work. I ordered a summit sending unit for the tranny but it doesnt seem to fit or look like the sending unit thats in the tranny already, even though its supposed to fit all GM vehicles...
thanks for any help =]
Old May 9, 2008 | 09:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedometer problem
If you want the mechanical speedo to work, simply swap the drive and/or driven gear to the new tranny.
JamesC
Old May 9, 2008 | 01:06 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You can't just swap the speedometer pickup from a 700r4 into a T5, the sizes are different.
You will need to go to a GM stealership and buy a pickup for a mechanical speedometer cable and the right plastic gear for your differential and tire combination.
Summit probably sent you a pickup for an automatic tranny if it doesn't fit.
Hope this helps.
Lou
Old May 9, 2008 | 01:35 PM
JamesC's Avatar
My bad, missed the 700R4 part.
JamesC
Old May 9, 2008 | 06:01 PM
no no no i have a t5 tranny that im swapping into the car.... my 700r4 is mech i dont care about that. I'm putting in the t5 which has a electronic speedometer sending unit on it already, i was wondering do I even need to order a sending unit for my new electric speedometer i ordered? I tried rigging up the speedometer to the sending unit on the trans but i couldnt get the speedometer to respond and yes i had the wires connected to a ground and positive but i just couldnt get a response out of it (ALSO the speedometer is a summit electric speedometer)
Old May 9, 2008 | 06:16 PM
BigBadLou's Avatar
Engine: TPI
Oh, so you will be installing a 90+ electronic speecometer as well?
In that case, you can reuse the VSS in the T5, no problem.
But you would need to find out whether the plastic gear on it matches your rear differential and tire combo. If not, you'd have to order a different plastic gear through the stealership.
Lou
Old May 9, 2008 | 07:31 PM
lol nevermind i took the mechanical gear sender out of the T10 in the nove and it matches up to the t-5 so im just gonna run my mech speedometer still
thanks
Old Oct 11, 2008 | 05:26 PM
interstate_35's Avatar
Car: 1992 Camaro RC B4C
Transmission: M5
Hello, Can anyone help. I have a 1992 B4C with the T5 with electronic speed sensor. I replaced the sensor and the speedometer still does not work. All the rest of the guages work, except the oil pressure gauge spikes way out. Is there a fuse, relay, any tricks you guy know???? HELP
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
