ALDL Cable problems.. firebird
Old May 14, 2008 | 01:12 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Why isnt that cable working on an 1994 Firebird LT1..
TTS Datamaster says that the com1 is ready and cable ready, but when the car is started and the "start" button is pushed it goes some seconds and then it says "PCM ERROR 1"...
Ive tried that cable in my 1989 Camaro and it worked well in tts datamaster.. (yes we have downloaded the right version of tts datamaster to the firebird to)..
That should work right, the firebird uses the same 8192 BAUD on pin M right ? Or shall I remove the 10k resistor to make it work ?..
If i look at akmcables they sell the same cable to 89camaros and 1994 firebirds.. so I figure thats the same cable inside too then..
any ideas of why it isnt working ?
Old May 24, 2008 | 10:10 AM
Theking's Avatar
Car: 1989 IROC-Z
Re: ALDL Cable problems.. firebird
removed the 10k resister and connected the B terminal directly instead.
Now when the cable is connected the fans starting and the SES light comes on.. still no connection to the ECM
why ?! shouldnt that work ? now when we removed the 10k resistor from B-A and only connected the B without any resistor..
any help is appreciated
Old May 29, 2008 | 12:42 AM
Theking's Avatar
Car: 1989 IROC-Z
Anyone ?! :?
Old May 30, 2008 | 01:12 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
IIRC 1994 & 1995 are (excuse my french) Bastard years for OBD1. Although they still fall under the Tech 1 platform some cars got a 12 pin (old OBD 1 type) and others got an 16 pin (OBD 2 type) but it was still running OBD1 wireing.
To top it all off some cars also got some extended data streams that were not on previous OBD1 type systems and create havoc with basic run of the mill Data readers and normal pinouts to have the flashing dash light for codes.
Its not all clear but that might be part of the problem.
John
9192camaro
16
Feb 3, 2019 12:21 AM
deracer
Apr 11, 2016 12:04 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
