Mystery hatch wire
Old May 24, 2008 | 02:38 PM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
Mystery hatch wire
Hey, can anyone tell me where this white wire is supposed to go? My pull down motor stopped working today and when I opened up the panel, there were about 7 frayed wires and this white one was connected to nothing. Neither of my manuals has a wiring diagram for the hatch. Thanks.
The wire is coming from the loom that has all of the wires going into the relay, and it has a very small black connector attached to it. Also, my BRAKE light comes on when I push the hatch release button.
Old May 24, 2008 | 04:14 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Mystery hatch wire
It should run to your trunk light. an orange wire and a white wire.
Old May 24, 2008 | 04:27 PM
87GTAj's Avatar
Engine: 5.7L TPI
No, my light has both wires attached and it works. From what I saw, there is no visible place for the wire. If anyone has a wiring diagram fro the hatch motor circuit, I could possibly trace it from there. As I said, the wire is coming out of the loom that has several wires going into the relay. Some are black, some blue, and a few white. This one was just sitting there - but it has a connector on it so I think it must go somewhere.
Old May 27, 2008 | 03:37 PM
coopta85's Avatar
Car: 86 Trans Am
I have the same mystery wire on my 86 TA. Anyone?
Old May 28, 2008 | 12:04 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Old May 28, 2008 | 11:21 AM
blove78634's Avatar
Car: 88 Iroc
Engine: 5.0 TBI
Keep in mind my car is in GA and I am in DC.
i was home last week trying to troubleshoot a tail light problem. When we had the panels off I want to say that the orange wire went to the right side of the contact (3 metal contacts). Check there.
Old May 28, 2008 | 12:15 PM
87GTAj's Avatar
Engine: 5.7L TPI
Thanks for the pic, but I didn't see where the white wire is coming from or going to in the diagram. Appreciate all the help guys.
Does your pull down motor work or does it not work like mine? If yours works then I would know that this wire doesn't make the pull down motor work. I'm starting to think it got dislodged from the contact sensor, but can't figure out how or verify that the sensor has three wires. It has two in it now.
Old May 29, 2008 | 09:59 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
If I remember, it's not used before 89. If you hook it up right, it will turn the trunk light off and on if the hatch is closed and opened.
Old May 30, 2008 | 08:13 AM
coopta85's Avatar
Car: 86 Trans Am
No, my pull down motor does not work. I haven't tested the motor or anything. I just bought the car and have limited time and resources. Whoever had the car before had massive speaker boxes in the hatch and I have mystery wiring all over the car, but most of that is just open wire with no connections on the ends. That one wire that is the same as yours is one of the few with a connector. I managed to get my hatch to close down tight manually and then I pop it open with the button on the dash. Would love to have the hatch motor operational but will settle with what I have now until I get some help.
Old May 30, 2008 | 08:15 AM
Axle/Gears: 3.27 BW
Originally Posted by lonsal
It is unused on your year of car. It was used on 1989-91 cars to turn on and off the rear hatch light. Your car has a manual switch. The later model years I already mentioned have that white wire plugged into a tan with white stripe wire. The wire switched off ground to the hatch light. If you want you can hook the ground of your hatch light to that white wire and the hatch light will be turned on and off automatically by the striker-sensing switch of the pull-down motor.
Lon
Old May 30, 2008 | 03:24 PM
87GTAj's Avatar
Engine: 5.7L TPI
How'd you get it to close manually? I've been trying and can't get it to stay closed.
Lon just told me the same thing, thanks for all the help.
Street Lethal
Apr 30, 2019 12:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
