starter wiring help
Old May 21, 2008 | 02:35 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
starter wiring help
After 2 years of being down today I pulled my Camaro out from the back yard to install the new engine only to find that the damn dog has chewed all the wires that go to the starter.
I know that the small white wire is for the knock sensor.
The purple wire still has the connector with a small end on itso I'm sure its to activate the starter.
The other wires are chewed back all the way to the wire loom and whats left of them are red.
Does all 4 of the red wired join together and hook to the post that the battery cable go to?
Dewayne
Old May 22, 2008 | 02:51 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Re: starter wiring help
yep. but you should have a purple wire that goes to the ignition post on the solenoid, too. so i'm assuming the dog chewed the fusible links, too?
Old May 22, 2008 | 02:58 PM
Car: '91 Z28
Axle/Gears: 323's
well, lemme correct myself a little bit. they all connect to the starter, but one wire goes to the alternator with a fus link. two of the other wires are spliced together and have a fus link, too. one of those wires goes to the big bulkhead connector and feeds your ignition switch and a handful of fuses. the other goes to the fan blower relay. the last wire goes to the fog lamp fuse and light switch, with yet, another fus link, and goes thru that bulkhead connector also. so in all, you should have 3 fusible links... hope this helps.
Old May 22, 2008 | 06:57 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
