does anyone know were is the TPS grounded?
Old May 23, 2008 | 08:15 AM
1988camaroRS's Avatar
I need to know where the TPS is grounded so that I can fix a code 22 Ground wide open throttle circuit
Old May 23, 2008 | 09:00 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: does anyone know were is the TPS grounded?
The ground is provided by the ECM (and shared by the IAT sensor).
You can measure the voltage on it against the block or other known ground. With the key on to check if it's at 0V.
Hope this helps.
Lou
BumpaD82
Feb 26, 2016 02:57 PM
billybob6110
Sep 23, 2015 01:30 PM
gta892000
Sep 16, 2015 12:37 AM
Glowsock
Sep 5, 2015 07:48 PM
