coolent temp sensor question
Old May 23, 2008 | 07:44 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
does any one have a schematic to show how the ecm and the sensors are all wired together?
im just curious to see if the coolent temp sensor from the front of the intake is directly connected to the engine fan switch.
and if the fan switch goes does that mean the ecm doesnt get information from the coolent temp sensor
Old May 24, 2008 | 09:38 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: coolent temp sensor question
Short answer: nope.
Long answer: the coolant temp sensor is a sensor, its resistance varies with temperature. ECM "sees" the engine temperature and turns on the fans via relays, if needed.
There is also an extra back-up temp switch (do not confuse with sender) on the V8 blocks that turns the fan on if the engine starts overheating. It's there in case the ECM fails to cool the engine.
You can find a lot of diagrams here: http://www.austinthirdgen.org/index.php?pid=19
Hope this helps.
Lou
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
squiggy2
Aug 9, 2015 09:30 PM
