Starting Issue on a 91 camaro
Old May 29, 2008 | 08:00 AM
ChampionN84's Avatar
Car: 91 Camaro Z28
Ok so i have a 91 camaro with a 87 tpi in it. Everything worked great. The obvious stuff has been checked. Batt Starter Alt wires. It won't click over at all. The only thing out of place is the neutral safty was not bolted in so i messed with that tried to ground it and nothing. I have 2 question I believe it is the neutral safty switch or the ignition. How do i test each or jump them to see what the issue is? Also on the ignition i have 2 power wires it seems purple which is constant when the key is on or in cranking mode and yellow which doesn't seem to have any power.
Old May 29, 2008 | 11:57 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Starting Issue on a 91 camaro
What do you mean the neutral safety was not bolted in? The whole automatic shifter switch was loose?
Here are some diagrams that will help you: http://www.austinthirdgen.org/index.php?pid=19
Follow the path of the starting circuit from the red wire that has constant power and supplies it to the ignition switch, throught he yellow wire that is the cranking wire, to the starter enable relay (under the driver side dash or behind driver kick panel) where the wire color changes to dark greeen, to the neutral safety switch on the automatic shifter, where the wire changes color again to purple and then directly to the starter.
If you follow this path, you are bound to find the failure.
Hope this helps.
Lou
Old May 29, 2008 | 12:17 PM
Car: 91 Camaro Z28
yes it was looose
Old Jun 3, 2008 | 10:31 AM
Car: 91 Camaro Z28
The yellow wire coming from the column was attached to the alarm which i disabled i just connect it back together and boom. Ignition!
Old Jun 3, 2008 | 11:00 AM
BigBadLou's Avatar
Engine: TPI
Glad to hear that even this murder mystery had a happy ending.
Lou
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
mizz0313
Aug 12, 2015 06:45 AM
86Base
Aug 8, 2015 01:34 PM
