tach stuck at 7000
Old Jun 7, 2008 | 07:46 PM
anthony714's Avatar
tach stuck at 7000
pulled engine last winter,dropped new one in with a new dist cap. its a standard hei..anyways i noticed the tach reads 7000.turning key on or off has no efect.if i crank it nothing. i havent started the engine yet..any ideas?im stuck...also everything the same as before i yanked engine.is it possible the tach just went bad?
Old Jun 7, 2008 | 08:17 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: tach stuck at 7000
do you have the tach wire plugged in? Is it plugged into the right terminal?
Old Jun 7, 2008 | 09:24 PM
anthony714's Avatar
white wire plugged into "tach" terminal on dizzy...pulled the gauge,theres switched power coming into the back side of the gauge/ciruit board/cluster
$750 L98
Feb 1, 2025 02:25 PM
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Eric-86sc
Sep 28, 2015 11:37 AM
TrevinE
Sep 14, 2015 03:20 PM
