truble
Old Jun 7, 2008 | 08:45 PM
bkcamaro's Avatar
Car: 85 z-28 and 96 z-28
Engine: 383 storker and a 350LT1
Transmission: 700R4 and 4L60E
Axle/Gears: 3.23 and 3.73
truble
ok i have and 85 camaro z 28. I have no speedometor wipers or blinkers. the only time the blinkers work is when i turn on the hazerds and even then only the left front and the right rear work. I replaced all the bulbs and checked all fuses. and to make things even more crazy is the arrows in the dash both turn on when i turn on when i turn the head lights on and only the left one blinks when hazerds are on or other wise they dont work. there is also 4 wires hanging from the steering colom pink gray blue black i checked the plugs for the wiper motor and everything was pluged in. the guy i bought the car from told me the interior was out of a 91 please help
Old Jun 9, 2008 | 08:36 AM
bkcamaro's Avatar
Re: truble
PLEASE HELP
Old Jun 9, 2008 | 09:24 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Re: truble
Ok, do you have the 82-89 dash?
or was the 85 style dash swapped with the 91?
IF:
you have the right dash for the 85 then all I can really tell you is pull the whole cluster out as one peice(four screws top and bottom, and then the two little nuts in the warning light holes, then it should come out without too much hassle)
After you have it out, check for any damaged wires in the circuit on the back of the cluster, and lubricate the speedo cable and when you assemble be sure it is firmly seated into the rear of the speedo too, or else it will make one hell of an annoying grinding-ish clicking sound.
Also, try cleaning the electrical contacts on the gauge, and the two plugs, and be sure it is firmly seated in there.
and if everything works out right, you have a working dash again!
However, if your dash was swapped for a 91 setup... I can't help you much here.
Also, if you do have the older dash, be sure there are no kinks in the cable, and make sure its connected to the tranny.
I had the same problem with my 88, post a response after you tried the above (if it applies) I'd like to know how it worked for you.
Old Jun 9, 2008 | 12:33 PM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
Re: truble
I have had similar experiences when I've had bad turn signal switches. An open here and feedback there will cause just such chaos--very frustrating.
Old Jun 9, 2008 | 12:46 PM
bkcamaro's Avatar
Re: truble
ok i replaced the steering colom so far and i have all blinkers when i have my hazerds on and when i leave the key in it make the buzzing nosie which i didnt have before but when i want to turn left or right they still dont work and my wipers still dont work. I also was wondering what the box to the right of the colom under the dash is for cuz it looks rought all bet up. if important would the one off my 84 work?
FormulaL98
Apr 4, 2022 04:25 PM
Black84T/A
Oct 21, 2006 08:07 PM
greg18269
Dec 26, 2005 11:02 PM
berlinettakid
May 7, 2004 06:01 AM
Hasselhof
Oct 18, 2003 12:18 AM
