90 to 84 guage swap
Old Jun 10, 2008 | 12:23 AM
wife hates it's Avatar
90 to 84 guage swap
can take the 90 dash and guage package out and put it in my 84. the 90 has a 6 and the 84 has an 8. what am i up against. i want to loose the useless 85mph spedo and at least put something a little taller in it. remember in 84 speed was 55 now its just a suggestion and i dont want to get nailed passing someone in a quick heartbeat because this stroker pegs the nail in a quickie. any help would be usefull.
Old Jun 10, 2008 | 06:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 90 to 84 guage swap
Not without major modification--moreover, the 90 speedo would be electric, the 84 mechanical. By the way, mentioning the make and model of your car is useful. If it's a Camaro, why not find a 110 or a 140 cluster (mechancial through 89, which means it'll fit your car as a simple swap)?
JamesC
Old Jun 10, 2008 | 11:07 AM
sorry i didnt mention it James they are both firebirds and im just now trying to build two out of one. there are no real issues with my 84 cluster i just like the looks of the 90. so youre saying i can only go as far as89 for the mechanical? if so start looking on *bay for parts i got some good ones thanks again. EX-WIFE HATES IT...... BUT I STILL GOT THEM
Old Jun 11, 2008 | 06:21 AM
JamesC's Avatar
Firebirds are different than Camaros. I'm not a bird kinda guy, but IIRC, birds are mechanical, 82-85, then electric to 92.
JamesC
Old Jun 11, 2008 | 10:52 AM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
in 86, the birds changed to an electric speedo. Do a search, i know that the swap is common and you should be able to find info as to what is needed. Also if you are changing the entire cluster, you will need to re-pin the harness because that part is different as well.
Ghettobird52
Jul 5, 2024 11:18 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
