tachometer pegged can 1 fix it
Old Jun 10, 2008 | 10:43 PM
ScottR91RS's Avatar
This is for a 19 RS with a 3.1
I just got it home after putting exaust on for emissions for title. It goes over heat and needed a heater core. When on the road it 60mph shut off to cost in for a long cool down cost in. The tach flicked to 1150 rpms with it shut off. SO MAYBE, Someone could help and say what to check before and or while I spend this weekend putting most every screw back in the dash. Also if you would like to suggest something else to check while the dash is loose I would be greatful.
Old Jun 10, 2008 | 11:17 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: tachometer pegged can 1 fix it
https://www.thirdgen.org/forums/elec...meter-fix.html
Took 2 second using the
Although I sent mine out to another member to get fixed, I don't like messing with electronic thingies.
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
