What thread type are the battery bolts?
Old Jun 13, 2008 | 10:21 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
My car is 21 years old; I have worn out the thread on the negative terminal to the battery. I have never heard of anyone ever doing this, but I have.
I am wondering if I should replace the whole main negative lead or simply replace the battery bolt. The negative ground wire to the battery is in excellent shape. The car has never been in salt, nor driven alot in rain, and its stored winters where I had been disconnecting the negative lead to the battery. i have done this so many times that the bolt is wore out.
Old Jun 13, 2008 | 11:15 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: What thread type are the battery bolts?
The battery bolt is special...5/16 head...3/8th's USS thread.
Old Jun 13, 2008 | 11:27 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Dyno Don, thanks, 3/8 thread is 3/8" in diameter, what is the pitch? Is that the USS that you show? I dont know what this is. I simply know pipe thread, course and fine thread.
Also, I have never removed a battery bolt from the connector. Does this bolt push out? And where would I buy one? Auto-Zone maybe?
Old Jun 13, 2008 | 11:50 PM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
I think they are 3/8-16, which is national course. Yep, the bolts just push out of the cable ends. You can get new ones at Wal-Mart, Autozone, etc.
Old Jun 14, 2008 | 08:35 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Great, thank you.
Old Jun 14, 2008 | 08:50 AM
Stephen's Avatar
Car: 87 GTA
I got the specific replacement ones at Autozone, that have bigger than standard heads, that allow jumpercables to be attached.
Standard battery bolt heads are so small, it was always hard to get a jumper cable to clamp on the head.
Old Jun 14, 2008 | 10:32 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
I bought the standard battery bolts at AutoZone this morning. They have the same small head on them, the standard Chevy battery wrench works on them. I am good to go!
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
