Tail light Wiring
Old Jun 14, 2008 | 03:44 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
Tail light Wiring
I have an 89 firebird and was wanting to do something different with my tail lights. All 4 lights light up when you turn the parking lights on and only 2 light up brighter when you hit the brakes. I am wanting all 4 to light up when I hit the brakes. Has anyone done this and how did they do it. I think I will need to switch out some connectors so the other 2 lights have the dual fillament bulbs instead of the single fillament. If I am on the right track please let me know. I believe that the 2 bulbs that light up with the brakes are 2057 bulbs and the other 2 are the 194's I think. I know they are different than the other 2. If anyone can help me with this I would greatly appreciate it.
Old Jun 14, 2008 | 09:08 PM
fallenleader's Avatar
Car: 1984 firebird
Engine: 2.8 v6
Axle/Gears: soon: A working car.
Re: Tail light Wiring
This is all I got, from my 87' service manual. It may not be correct because yours is an 89'. but it might help.
Old Jun 14, 2008 | 09:35 PM
nknight's Avatar
Car: 88 Firebird
Engine: 305 TBI
i have a 88 firebird and i converted them to the 82 style wiring. what i did i get the taillight harness from a 82-84 trans am. and under the steering column on the brake light switch, you have to cut the brake wire and tap it into the white wire on the ignition harnes(the one on the end). let find the link to wiring instructions. but its fairly easy. once you got the 82 harness the only modification you have to do is under the steering column and your taillight will function like the 82-84 trans am. 6 parking lamps, braking and turn signals 2 inside lamps on each side. but i then added sequentials once i did the wiring coversion.
let find that link for you
alex
Old Jun 14, 2008 | 10:43 PM
nknight's Avatar
Car: 88 Firebird
Engine: 305 TBI
hey gambit,
here's the link
http://www.austinthirdgen.org/index.php?pid=37
it is easier if you find the taillight harness from and 82-84 trans am or gta.
no modication is needed. just swap the harnesses, then your can use trans am or gta taillights.
hope this helps,
alex
Old Dec 6, 2012 | 08:10 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
hey nknight,
is there any other way to access the info on that seq mod??
it reeaally looks nice on your replica!
Old Dec 10, 2012 | 06:30 AM
ownor's Avatar
Engine: LS1 / L03
ok so by googling "austin third gen wiring pid=37" you can actually find the link nknight was referring to, then in the preview click "Cached" to get a copy out of google's cache - since AustinTGO seems to be down now..
Anyways, i was actually looking for a description on how to make these awesome sequential turn signals?? Might be better messaging nknight tho to not hijack this thread.. sorry
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
